I cannot get this drum off, I already have another drum and backplate on order because I've ruined this one trying to get it off. Completely rusted to splines. I cant fit any hub or wheel puller known to mankind onto these lug studs to try and pull it off, I'm really running out of ideas.
Try to heat it up. Not crazy hot just enough to make the metal expand. Use a rubber mallet and keep banging around the edges.
Use a plumbers type map gas torch for sweating pipe.
Don’t give up after the first time. Heat it bang it etc.
Can you turn the axle when you're trying to pull it off? If not then your shoes might be wedging inside the brake hub not allowing you to pull it off. Also what Frank said, plus add some penetrating fluid.
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
    • By exalrod
      Hello All !
      Could anyone help with this?
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By RRP
      My new 2023 Polaris Sportsman 850 is in the shop for a pinched Wiring Harness from the factory...
      I did one ride on it (100kms), then to the shop for a month, waiting for them to replace it with a new one.
