My buddy has a trx and as far as he knows the only thing done is the green wire mod. My ltr has a yoshimura exhaust, cherry bomb, and air box lid off. His trx pulls on mine all day. I thought with those mods on the ltr I would win in a race? What should I do next to it?
Big bore kits are around 400. You can do cams, timing advance, rev limiter box for more rpms. Port the head and intake. Port the carb. And so on. It depends on what your looking for. I have the 440 kit and stage 2 cams and keep up if not pass the 450s.
    • By marlon smith
    • By harryjr
    • By hunky
      Thanks for looking!
    • By goatman
      quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
    • By goatman
      bottom of the tail pipe was rusted out and the little nut also ripped off when i tried to undo it.
      a 540 ml soup can is the same id as the exhaust pipe od and the soup can has ridges to make it a tight fit
      a little bit of a mickey mouse fix but it works
