2011 Crown Vic here with 305k miles, and today my engine light comes on. Scan at the local Advanced comes up with 4 codes on the cat converter. Guy says I need to get something called Cataclean and run it through the gas tank to correct the problem.
Is it worth doing this...will it make the engine run better or get better gas mileage?
Should I use Cataclean or some other product to get this done?
Cataclean doesn't always work and if there is an underlying issue it will not solve your problem. But, its a cheap "worth a try". What are the codes that came up?
Sorry it took so long to get back. The check engine light went off but it came back on yesterday so I got the codes read again. Guy's machine read 4 codes but said they were all the same code...P0430.
I'm game for the lacquer thinner option I've been hearing about. I see low voc lacquer thinner for sale. Wonder if it matters which version you use?
Did the light come off on its own or was it cleared? That code can be a bad converter but can also be some other things:
https://www.autocodes.com/p0430_ford.html
Possible causes Faulty Three-way Catalyst Converter Bank 2 Exhaust Tube Intake Air Leaks Faulty Oxygen (O2) Sensor Faulty Fuel injector(s) Leaking Fuel Injector (s) Faulty Spark plugs Improper Ignition Timing Faulty Engine Control Module (ECM) Dirty Air Filter
Tech notes As the code description implies the P0430 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem. If the P0430 code is combined with other codes, try fixing the other codes first.
Thanks EC.  Great info in that video there.
The check engine light went off (dark) on it's own after being on for only a couple days.  After staying off for maybe another 2-3 days it came back on again.
Have advice it might be my intake manifold leaking, but it was replaced new w/ OEM last year so that's probably not it.
New plugs as well.
I'll go ahead and replace the air filter just to make sure.
Also, the engine takes about a quart of oil every 1000 miles or so.  I don't see any drips in the driveway but I don't see any smoke from the exhaust either.  Not sure where the oil is going.  I was assuming it was leaking out only when it's being driven.  Been told if it's burning oil that could be causing this code as well.
    • By docdoug72
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By carkivey3
