2012 Rancher ES-- only when driving in 4x4 when I get to about 15-18mph there is a loud clunk in the front end and a hard downward jerk. Its almost as if its trying to downshift itself. It doesn't do it in 2 wheel drive.  I have checked the angle shift sensor and applied dielectric grease to it, changed the front end differential fluid (the old still looked good and clean) checked and adjusted the clutch. Hopefully someone can give me some more ideas.
Edited by Jeni Lynn
Have you taken the differential cover off and inspected everything ? Also try to get the bike off of the ground (all four wheels) safely and put it in 4wd give a little throttle maybe you can listen in and see what’s happening.
haven't taken the cover off yet. I read on a different forum to check the psi in your tires that it could put stress on the front end. Mine were very high so I let air out to put it back at Honda Specs.  It seemed to help a. little... but now its more prominent when I'm slowing down.
Unfortunately your going to have to go through all of the components of the drive train to see what’s going on. Inspect everything, drive shafts, universal joints etc.
You could be doing more bad then good by running it.  I don’t think that the tires would do that but what I would double check and super important is the size of the tires.  If the fronts are severely worn out it could cause a problem because 4x4,s must have all four tires rotating at the same time.  So if one set of tires are worn out the tires essentially become smaller and rotate faster then the others. That can screw up the 4x4
last thing I would recommend is double checking all of your motor mount bolts, shock mounts and bushings etc. make sure nothing is jumping/banging because of a broken or missing bolt.
Your welcome.
I hope it’s something relatively simple.
Any questions you might have ask away.
Also post some pics as it makes it easier to visualize  something with a pic to help you out and don’t be shy there’s no such thing stupid question related to a quad repair.
Good luck and yes please keep us posted.
  • 4 months later...
  • 2 years later...
      View File 2012-2026 Polaris Phoenix 200 service manual
      Download the 2012-2026 Polaris Phoenix 200 service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This Polaris Phoenix 200 repair manual includes detailed step-by-step instructions, diagrams, specifications, and service information for maintaining and repairing your ATV.
      The manual covers all major systems including engine repair, fuel system service, carburetor adjustment, transmission and drivetrain maintenance, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, maintenance schedules, and factory diagnostic procedures.
      Whether you are performing routine maintenance, fixing starting problems, troubleshooting electrical issues, or rebuilding your Polaris Phoenix 200, this factory-style service manual provides the information needed for DIY repairs and professional service work.
      Topics covered include:
      Polaris Phoenix 200 engine repair
      Carburetor and fuel system service
      Brake and suspension repair
      Torque specs and service data
      ATV troubleshooting and diagnostics
      Popular related searches:
      2012 Polaris Phoenix 200 service manual PDF
      Phoenix 200 wiring diagram
      Polaris Phoenix 200 troubleshooting
      Polaris Phoenix 200 carburetor adjustment
      Phoenix 200 maintenance schedule
      Polaris ATV service manual PDF
      Perfect for Polaris ATV owners, mechanics, and enthusiasts looking to maintain, repair, or restore the Polaris Phoenix 200 youth and recreational ATV models from 2012 through 2026.
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
