i took my 1987 honda trx 300 4x4 out today threw some creeks and mud it did fine for about the first hour then it all of a sudden got real hot and started steaming i no the water would make it steam but it wasnt like a water steam or an oil smoke it was just like a light steam coming up threw the plastic around the handle bars just wanting to know if i should be worried. it still drove fine and had all of the power it was just steaming. i shut it off for about 5 min then it did fine the rest of the time.
thanx
Andrew
Well then that shoots my theory down. You can usually smell if the steam is water or something else.
Not really my Ozark will put steam on you when it drips on the engine and exhaust . During and after water or mud playing.
  • Admin changed the title to 1987 honda trx 300 4x4 should I be worried??
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By toe420
    • By TomJulio
