That is a 67 RS that I built with my son in our garage. It was an awesome experience. Shifting is very hard to move out of park. I just bought this ATV from a person my wife works with. They gave me a folder with receipts for service from the Polaris dealer. They never had any issues just did routine maintenance. It has 252 hours on it. Do you think I should change fluids?
Well I would just double check that all the fluids are up to par first and see how the oil looks and feels.   Have you looked at the shifter to see if anything is obstructing it ? Does it look like it was removed and reinstalled?
I checked all fluids and they seem fine. I might go ahead and change again to be sure. There is no obstruction that I can see on the shifter. It shifts smooth from one gear to the next, but moving from Park you have to really tap it or push pretty hard until it moves.
I have tried rocking it and it does make coming out of park easier. It just feels like linkage is out of adjustment or bent. May just be me not being used to the shifter yet. It runs great and all fluids look clean and don't smell burnt or anything. I was just looking to buy replacement fluids on amazon. They sell the Polaris oil change kit and other fluids. What do  you recommend about places to buy fluids and should I look at synthetics or stay with Polaris recommended.
2013 550 xp, was hard to shift from new. I use Mopar atf+ 4, and motorkote hyper lubricant , Shifts like butter trans stays cool.
Also use in rear diff  and engine. Rear  diff was always  very warm. Now  with aditive stays cooler to touch .
 I found ATF+4 to be the  best after  many other  fluid trials. And even without motorkote, was slick  shift.
    • By Thekevinjb
      thanks
    • By oxidized_black
    • By JMSwed
      Hi EVERYONE
      New member here
