I have a 2003 Polaris Predator 500 . I know my valves need adjusted . Here recently I`ve had to bump start it . And i noticed a power differents  . Now it won`t bump start . Did i mess anything up ? Or can I still just adjust the valves . By the way does anyone have a video of how to do a valve job on it ? Let me know ASAP !!!??? Thank you
Why do you have to bump start it? does the starter work right or not ?.  assuming you have an undamaged battery,if the starter is not beeing powerful enough you could have  a charging problem that's causing   a decrease in power delivery . as mentioned in the previous post the fault is not the valves rather than  an electric one.
    • By realpilot
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By OldATVowner
    • By cruteg8
