i did that and nothing it 's exhaust smell's normal when i start it and then i went 1/2 a mile and it smelled like burning oil  then a mile and it smell's normal but no smoke. it loses a quart a mo
I would def do that and if possible take the valuable cover off so you can see the valve springs. Take WD 40 with the red hose on the top and spray it on the stem of the valve where the seal is. There should be bubbles where the seals are if it’s leaking as you spray it.  I like to use windex or a soapy solution but then you have to change the oil.
  • Thanks 1
Bottom line is your losing oil. Weather it be a leak. Wash down the entire bike including the under side and start looking.
Or it’s valve seals and or bad rings.  You have to see some smoke I’m sure.   Like I said compression test and also pull the spark plug and see what color it is.
so i have not got around to doing the compression test and now it started to smoke black and i read that that means to be to rich when it is to rich does that also mean i am losing oil thru it being to rich
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By crankin
