I think it will need a Set of Paddles....
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Jim Denton
      File limits have dropped for me. Down to 85 KB. I can only get my pics down to around 1.5MB. Have the limits changed because I'm a free member? This is on posts. I made an album in the pics section and wasn't throttled so hard. Just wondering.
      Thanks, Jim
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
    • By Rich1028
      Video from Leota Michigan on our Honda 400's
      5-30-2020
      Was A nice Afternoon.
