I have a 1999 250 Yamaha bear tracker was told it needed a coil to run got into it to day found out that the kill switch was wired together then I found were they put a new cdi on it they cut all the plugs off the stator wires and the cdi wires I found bits and pieces of wireing diagrams blue pick up wire to red and white green wire to white and green wire rolled it over Had a test light on the coil wire it showed there was juice going to it but no spark on the plug and the coil is a brand new one put it on before trying to test the spark did I miss something or have something hooked up wrong already have plans on a new cdi and stator and pick up coil before I go that far like to hear it run. Thank you for the help in advance
Hey @Bronson Weddle welcome to Quadcrazy. I know that bike well.  So it sounds  like someone hacked the  sh** out of the harness. The cdi and parts that you ordered are they oem? The stator can be aftermarket but the cdi should be an oem.
The plugs that are cut off were you able to correct that ? The new cdi needs plugs so how did the previous owner splice it in and also the same question for the stator ?
Its hard to say if anything you did was wrong or not because the harness was so beat up. I will take  a look and see what i can find in my old diagrams to help you along but i would take the path of trying to get it back to the original state with the wiring and i mean locating new plugs etc.   Does it look  like the stator is original? If so you can do some quick testing to see if its good.
I did a ohm check the pick up had 4.38 the black to green red to blue the stator did not put out nothing with just the key on then I cranked it still nothing am just going to replace the stator and the cdi Already have a new coil. And can tell me if a big bear rear brake assembly will on the bear tracker I have the brake part that the levers work the brake but don’t have the spacer or the hub I know some that has back assembly but it for a big bear or honda fourtrax but what I could tell it looks the same like what’s on the four wheeler. I let u know when I get into replaceing the stator and pickup and cdi. Thank you for answering me I can use all the help that I can
When I got the quad they said they replaced the stator and coil but after further investigation it original
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By crankin
