  Something i have wondered for years is about the firing order of a parallel twin.  Yes i am aware of both pistons going the same direction at the same time, but do both cylinders fire at the same time or at different times? Just being curious since i have always wondered.
Parallel twins don't fire at the same time. While one piston is on the way up to fire the other is on the way down.  They are designed like this so there is a constant velocity power band and produce a lot more torque.
Tandem twins have the pistons firing at the same time as the pistons are at the same location on the crank shaft.  These are a pain in the as* to dial in since the air/fuel delivery to the cylinders has to be very close because they both fire together.
    • By Olchap
      Thank you,
      Olchap
    • By David Land
      I have an 05 King Quad 700 that has in the past had to have the stator replaced twice.  For the past six months it has been down hard as I cannot get it to fire.  I have replaced the coil (which is the code that came up) and now I have a friend replacing the stator.  I want to see if the new stator does the trick.  Drain the old fuel, and replace with 100% Ethanol free fuel, and see if that does the trick.  The local Suziki dealer will not work on it as it is over 10 years old.  So the nearest dealer is 90 miles away.  The last thing I can do after that (provided the other fixes do not work) is replace the ECM/ECU.  I also read that there was a recall on the ECM/ECU, so I need to check on that.  All of the grounding has been checked, so if anyone has an idea, I would greatly appreciate the insight.
      Kindly,
      David
    • By TravisCr
      I know the downloads are out there- but I'm a paper guy at heart- anyone have one they'd like to move on to me?
    • By TravisCr
      I bought this from a buddy to plow snow up in the North Eastern Washington- its been getting oil in the water and I've been changing the oil often and adding collant as necessary-
      I've taken the stator cover off and I'm looking at the Oil Seal and water pump seal and they look good- Although I've ordered a factory oil Seal I'm looking at putting it in this afternoon-
      I don't have the factory service manual- am I suppose to Add RTV to the Stator cover Gasket? I've seen some folks suggest grease other suggest RTV?
      Any suggestions here- I'm trying to reassemble it tonight- I looked at downloading the manual but need to get up to 10 posts firsts it looks like-
      I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but  I got a good deal on the quad and a plow so I went for it
      Its got a bit over 3K and runs pretty good- but I've had her tore apart for 3 weeks to figure out the oil in the coolant issue.
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
