Good Morning All!,
After a significant amount of reading and tinkering, I'm stumped.  We have a pair of Arctic Cat DVX 90s (4-stroke), and one of them runs very rich at wide open throttle.  I've cleaned the carb (which was installed new  last year), verified the main jet (80) to be per the original spec, installed a new air filter, tried a hotter spark plug (CR6HSA), and adjusted the valves (tightened a modest 0.0005" but improved starting).  The hotter spark plug may have help just a bit, but not appreciably.
Just for fun, I swapped the CDI between machines, and that didn't help either.
Fouling plugs very quickly, but not to the point the machine will not run or start.  [black instantly]
Logically, I assume I'm revving out, but the other machine doesn't "stumble/blubber" anything like this one.
Should I try a smaller main jet?
Any ideas you guys may have would be much appreciated.
Thanks in advance everyone.
Update/correction.  Swapped everything around today again between the two quads, and the stumbling is dramatically less notable with a CDI swap.
New Question:  I assume I should replace with an OEM CDI, but is there a better CDI made by an aftermarket manufacturer?
Thanks again guys!
    • By tepin
    • By Brent Wright
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
      Hello there
    • By TravisCr
      A year or so back bought a used 2003 Polaris Sportsman 700 Twin with a plow for keeping the gravel road around the house snow free-
      I've used it for the last year and it works well- have a bit of water in the oil I started a separate thread on.
      Are there any "gotcha" on using these things with plows?
      I took off the small polaris winch and added a Warn 2500, with synthentic rope so I wasn't getting poked by the wire-
      Looking for folks thoughts on these.
