Hello from Manitoba!
Similar Topics
By gillies_robert
Good evening just like to share my current project, which is #8 in my fleet of Polaris.
By Budman
After purchasing a lightly used 2018 570SP (300 miles on it) I noticed that the display was flashing on and off. I remember reading awhile back that this was a common problem on the 18 model. I can't remember what the fix is. It also turns over slow even though the battery is charged. Anybody know what the fix is on this issue?
Budman
By buzzar56
I am looking for a free repair manual for a 2003 Polaris sportsman 500 ho atv. all the posts on here lead me noplace
thanks fred.
By Bryzan3
Looking for advice on what to try next I bought this quad and it’s has spark and fuel but won’t stay running only fires when I hold the starter button in even when spraying gas into the carb it still dies right away oil was milky white so I was thinking it maybe went under water 150 psi compression so I might be wrong but not a head gasket I am stuck Cause it should stay running with the straight gas through the carb so what should I try
By Wiley1
Anybody know what the valve clearance is for intake and exhaust on a 2017 sportsman 570? I did a search but it came up with nothing.
