What the hell does everyone use to pull a flywheel/rotor on a 99 yamaha bear tracker 250? I have looked online and they show 2 or 3 different ones. Finally figured mine out and need to remove the stator rotor to repair the starter gear.it wasnt installed correctly causing my issue of it just spinning the starter
The first one that @Ajmboy mentioned is the one i was talking about.  Its good for a variety of flywheels.
As far as your starter spinning and saying it the part wasn't installed correctly im assuming the starter clutch is in backwards is what you mean?
So to hell with this damn quad. I got the gear in properly, with new yamaha circlips, got it spinning over and after about 10 times it i assume kicked the shaft out again since it sounds like it is freespinning again. I am done with it. Thanks for all the help. If anyone wants to buy the damn thing be my guest
    • By cfherrman
    • By logray
    • By OldATVowner
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
