1989 moto 4 350 OEM spec carb problem.
By joshualutz
By USRaider
Hello all!
By kawasig
Hello there
By tin
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
