1999 Yamaha Big Bear 350 4x4 Front End Squeal
By
John Victor, in Yamaha ATV Forum
Similar Tagged Content
By hutchir3
Hello Folks....new to the forum. I have two Warriors (87 and 92), and an 89 Big Bear. Looking for some help with engine issues on the warrior, and my 89 Big bear backfired and died. Got spark, got gas, seems to have compression, (but haven't tested it yet...next). She rolls over good, maybe too good...seems soft. Have spark and enough compression to blow gas mist out the plug hole when cranking. Suggestions, Been running great since we got it.
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
By Samwise
View File 1987-1999 Yamaha Big Bear 350 4x4 Service Manual
YFM350FW
YFM350FWT
Submitter Samwise Submitted 12/04/2020 Category Yamaha ATV
Similar Topics
By AKMichael
Hello All,
Thank you.
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By mike91
By hutchir3
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
