Kawasaki Prairie 300 Rear Differential?
Similar Tagged Content
By oxidized_black
1997-2002 Kawasaki Prairie 400 Service Manual
View File 1997-2002 Kawasaki Prairie 400 Service Manual
By Chopermech
Check this out:
I have been working on these and trying to get the word out on the forums.
I am now at the point to be able to start doing struts for others. If you haven't kept up with my progress, I have developed adding external reservoirs. It would be an approximate $(contact me for current pricing as some things have gotten cheaper and some have not) cost for both struts which includes adding bungs and all parts, including a lower magnetic drain plug. It would be a complete assembly ready to install with minor tweaking once on the atv (such as line routing) but nothing significant
Send me an email if you have particular things you want done or suggestions based on problems you are encountering with the oem set up. I can help you decide which route to go.
Here in the following pic of my manual, is a list of OEM part number struts I have developed this program for. Basically, it will encompass all SRA's with a front strut like the one in the picture, even the ones with a slightly diferrent lower spring perch.
If you are interested in an affordable and better front suspension on your utility SRA, please email me at: [email protected] to ensure I get your correspondence, since my inbox on the forum periodically fills up.
http://www.kawieriders.com/forum/showthread.php?p=1314451#post1314451
By Jim Waters
hi everyone. recently iam get a good vibration that comes and goes while iam riding my praire 4x4. iam afraid something is going to detonate. vibration is felt in the steering and then you will here a noise and this comes and goes. its very noticeable when iam on a blacktop surface. iam worried. i cant get any slop in the drive joints i can grab onto. so any input would be appreciated. i have a manual downloaded and i,ve went through it pretty good. my thought is its from the output shaft to the front drive. let me know if anyone has experianced this.
By Sonders
It appears that the Service Manual thread at top of forum is dead as all the links no longer work. I'm actually looking for service manual for a 2000 KVF300 Prairie that I just picked up. Does anybody have link to one that they can share, or know where I can find one? Thanks in advance for any help.
By Spartacus Stroppel
View File 1999-2002 Kawasaki KVF300 Prairie Service Manual
1999-2002 Kawasaki KVF300 Prairie Service & Repair Manual
Submitter Spartacus Stroppel Submitted 08/25/2019 Category Kawasaki ATV
Similar Topics
By BrunoNogueira91
Hello, I am restoring a bayou 220 here in Brazil, I have a question regarding the rear brake activated by the lever on the left side. The ex-owner connected it in place of the reverse cable and as this is incorrect, could someone show me through pictures where I correctly connect the rear brake cable? Another thing, every time you reverse, is it necessary to activate the reverse key?
By chimmike
Anyone know where to locate these, or generics? The generics I seem to find have the mount on the wrong side versus the hose outlet. PITA!
Also, is the rear master cylinder rebuild kit any good?
By Lance Workman
Kawasaki Prairie 700 is the machine. It’s starts and runs but has a miss. After running it til it’s warm, it’s start smoking like your spraying for mosquitoes. Has oil in the breather also. Checked compressions and getting low 40psi both holes. I know this has a decompression lobe. Any other ideas? Leak down check? I’m guessing it pretty much has to be rings. With it blowing oil back into the breather. Normal typical sign I suppose?
By emoyer105
I have a Yamaha Timberwolf 250 2x4 that I purchased a while ago as a project. I fixed it up to where everything was working great in my opinion, however when I showed it to a potential buyer he complained about a vibration from the rear drive shaft. (Which I ridiculous seeing as he tried to wheelie it before that) Anyways I took the rear diff apart and found most of the seals and bearings where bad. So I bought a kit off of amazon only to find that it doesn’t have all of the bearings and seals. After finding that I decided to try to find a used good condition replacement but they’re all to expensive for me so is there a better alternative for me, or can someone point me in the right direction to get the rest of the parts?
By Lellwyn Griffin
I think my rear brakes are stuck. Is these parts in the right position? Any idea how I repair? I have to give it more gas to go and I can't push it when it's in neutral.
