2000 bayou 220 Stator Cover Gasket
Similar Topics
By Maddie3142005
Bet you've never seen a Tonneau cover that can hold 2 - 4-wheelers on top of it. This is a home-made heavy duty fiberglass truck bed cover that was used on an 2000 F-350 with an 8' bed. We have used it hundreds of times but are getting out of the 4-wheeling fun. You can waterproof with a rubber seal, not included. This leaves the area under the cover open for all your gear and firewood. It is white and in great shape. 4-wheelers NOT included.
By AtvNewbie
Can somebody help me on my issues? i bought new stator for my 1987 big bear 350 4x4, (1) it seems that the old owner replace the pickup coil with same color aftermarket pickup coil, i got no idea which pickup coil goes where on 2 spot, new stator have the right colored wire for each pickup coil btw,
(2) new stator got brown and green wire connecting to cdi but my cdi got brown and red, anybody got idea if brown go to brown and green go to red? Thanks
By Gsk1500
The clutch cover goes on and fits, but the little L chapped arm that has gear slots is concerning me. It appears it goes to wear the clutch adjust bolts are on the cover.
Is there a specific way to tell how it mounts on the gears in relationship with the basket?
I don't want to deal it up unless it's right
By marek porowski
Good morning everybody
I’ll be looking to get a cover for my Polaris sportsman touring that can be used while I take my atv to the lake for ice fishing.
min using an open flat trailer and
I want to protect it from the road salt
I know Polaris makes a nice cover but it’s kind of on the expensive side. I’ve seen some covers on amazon and eBay but was wondering if anybody has any suggestions
By Daniel Gibson
Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
