It may only need a top end, if it sucked in dust it ruined the rings. I had this happen to my 2007. The later years with it since it had high miles it needed to be bored. Ran great after that and I sold the machine.
Mike
    • By kevinohio
    • By kx9m
      Retired carpenter here looking for things to do... What else??  Work on old quads sounds good!!
      Here for manuals and advice..
    • By Ejwill
      My 2007 trx500fe is smoking at Idle and while running through the gears. It’s white to grey smoke not black. Give me the bad news like top end rebuild or something. I know it can’t be something easy. Any help will be appreciated.
      Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
    • By Need-help-with-quads
      So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
