Hey I'm looking at purchasing a 2006 Arctic Cat 650 H1 SE but don't know much about Arctic cats, how reliable are they and will it make a good Mudder/work horse?
Here is a link to the one I'm looking at
https://www.kijiji.ca/v-atv/edmonton/2006-arctic-cat-650-h1-se/1507897599?utm_source=com.atomczak.notepat&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_android
Sent from my LM-Q910 using Tapatalk
Arctic Cat has been a really good workhorse historically, but they're not ideal for a mud machine.  If you want to submarine it and throw it into the bounty hole, stick with Honda 300's or at least a 420.  Arctic Cat is a great bike but there's no user community to support them as mud bikes.  They're great for trails or farm use.
    • By mehim
    • By logray
      Hi all,
    • By tepin
    • By Shorty51
