I am working on a friends 2006 Suzuki LT-Z50 that they purchased not running. I took apart the carb to rebuild it and someone had already been in there... They really destroyed the Air/Fuel Mixture opening in the body of the carb.. It is in no way repairable.
I have not been able to find an aftermarket carb to fit this model.
Does anyone know if an aftermarket carb is available?
Thanks for any help.
Thanks for the response...  It is weird , Suzuki used that carb in 2006-2009 and then started using it again in 2017-2020 in the 50cc. I think this is the only carb I have come across that does not have an aftermarket version.
I am currently working on an intake manifold plate that will let me use a different carb.  I will post results and pictures...
A little update. After refusing to pay $300 for a new OEM carburetor, I built a new intake adapter that lets me use a Suzuki LT50 carburetor that I got on Amazon for $15. Now that the engine is running better I have discovered the next problem. Compression is low.... I will take some pics of the adapter today.
    • By jay41198
    • By kevinohio
    • By buriedpast
