1993 Suzuki LT230E quad runner rear shock
By jwh
By Coyote251
service manual - 2016 Can-Am Outlander L-Series
By geezer99
I have an Axis 500 made by Hisun. I uses a solid rear gearbox with no differential action.
I would like to convert this to a true differential with locking ability. I've searched all over trying to find a source with no luck.
Has anyone done this before, or know of a source?
Thanks, Tom
By Hagbard
Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
By Joeguy
I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
20241009_123850.mp4
