Good Morning!
Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
Thanks in advance.
I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
