I've noticed that the tag isn't embedding images within a post; rather it hyper-links it.
This may have been mentioned/covered but, I've not been on the site for a while.....
I'm using Firefox 2.0. I've also tried with IE 6.
Anyone else not seeing embedded images?
Thx...
-TD
Hey txduggan, thanks for bringing this up to us. Would it be possible for you to give me a link to a post that is not showing images, and I'll check it in Firefox and a couple of other browsers?
Are you using:
[img=your image url here]
http://www.quadcrazy.com/atvforum/pictures-videos-board/3444-action-shots-5.html
Are you using:
I'm pretty sure I hand-coded .
Let's see....
Yep...hand coded the above and it's a hyper-link.
Done from Firefox 2.0........
Tom D
Images in that thread and the image in your last post show up fine on my end in Internet Explorer and FireFox 2.0
I know you use Firefox, below is a screenshot I just took to show that it comes up. Now the hyperlink it displays for the image, clicks trhough to the image as a pop up?
Anyone else have this issue?
Interesting....when I'm not logged on, I see the in-post images....
I just logged on and they're back to hyper-links.
I'll check my profile settings next....
-TD
Yep...somehow my settings got gorked.
Mystery solved.....
Thanks!
Tom "I used to be smart" D
Great! Yeah there is a Display Settings area in the forum User CP. Thanks for taking the time to troubleshoot it. I don't know why I did not think of that on...:huh:
Unfortunately, I'm in IT and troubleshoot for a living....BLEH...
As the old adage goes, "It worked before!" LOL!!!!!
I know I didn't change my profile, so I'm blaming it on the tree huggers who hate ATV'ers....and I'm also blaming Lindsay Lohan......
Tom D
  • Admin locked this topic
    • By HoldenBoy
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
    • By WyattLemke25
      Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
    • By JoeB
      Considering pulling the pin on an ARGO xplorer 570 xrt 2 up unit. Has anyone had any experience with these. They offer a pretty good sounding warranty but I don't know anyone who's got one to know if they're good about following through on their warranty promises
