Suzuki LT230s kick start wont stay out
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By mga
By Need-help-with-quads
Can anyone help me?
By semicolon
By HSTAR
