2006 Arctic Cat 500 won’t stay running after ramming into a snow bank while plowing
By dhallftworth
Hi everyone, I received a 98 Yamaha Timberwolf from my brother for free, and I'm working on getting it going.
I am having the following problem:
The engine is backfiring through the carb.
I have done the following to try and get the four wheeler running:
Rebuilt the carb and set the air screw to 1-1/4 turn out and the circlip at middle position 3
Replaced the coil, because the cable was loose at the coil end
Repaired the main ground, coming from the battery
Replaced the ignition switch, because my brother couldn't find the key. New switch tested good
Tested the kill switch and it tested good
New coil tested goodfor both primary and secondary coils
Pickup coil resistance is at 195, which is correct
My source coil, is where I believe the issue is. The resistance is 310ohms, and it should be between 428-523ohms
When I opened the stator housing, there was significant oil, which I have read is normal. Does it sound like I'm on the right track replacing the source coil? Could this be causing my backfiring issue? It looks like the source coil is part of the stator assembly, is this correct? 4BD-85510-20-00 STATOR ASSY
By Sofaspud
By Am2007
Hi everyone,
owner manual
service manual
engine manual
By p5200
20240217_114429.mp4 -
By Ajmboy
So we are almost a month into winter and I've been so busy working on my house that up until today, I didn't realize that we just haven;t gotten any real snow yet to warrant putting the plow on my grizzly. So that got me thinking, what are the latest plows out there and what ATV plows are the best? I've got 2 snow plows for my grizzly, a quadboss pile driver atv plow set up and a snowsport ATV plow. They are both a bit dated now and I tend to stick with the snowsport due to ease of use and I just like it so much. So if you have a plow on your ATV, please let us know what it is and post a picture with your atv/plow would be awesome. Would also like to know what you like and dislike about it.
