Odd issue I'm hoping you fine folks can help diagnose. Recently rebuilt 800XP with new crank, rings, etc. Rod bearing went south so had to replace the crank. Got it back together fine, but only starts at half throttle and doesn't really even want to do that. Checked timing again and dots are perfect, compression 170 on both cylinders, fuel pressure 40ish.  Anything I could run down that I'm missing?
Could the injector wires be crossed ? Or ignition ?
Even though the valve timing is right, it may not be phased with either ignition or injectors.. Seen it on cars.
@Mech Good call, turned out to be injector wires crossed.  I helped my oldest rebuild the motor and drop it in and he put it all back together.  Woops.  The tip was last night when I could smell fuel a bit while cranking it over.  In EFI the only possible reason to smell fuel while cranking is no compression or a mismatch in squirt and bang.  I knew timing was perfect, that only left fuel and the spray pattern was clean.
    • By Elk
      2002 Polaris Magnum 325
    • By Dsluder
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By Jdeaton011989
    • By MikeDB
      Greetings to all.  New to the forum, but not to ATVing.  I started when they only had 3 wheels!  Getting back into riding.  Polaris 850.  Too many bells and whistles, but what do you do.  Scouting out places to ride legally now.
