  • Ajmboy changed the title to 2013 Bennche Bighorn 400 Charging light
Hi, did you still need help with your Bighorn 400?  If you're replaced the charging coil / stator.  I would say your remaining culprit for sure is your regulator-rectifier, they go rather often, gone through 2 myself.  Quick check, put your meter on the battery, note the voltage (12.5V~), then start the machine.  If the voltage stays the same or drops slightly, or even rises a little bit but stays below 13v, I'd strongly suspect the regulator is blown - no charging.  You can also quickly check your new stator - I think 3 wires.  Disconnect the 3 wires, does each one show maybe 20+ volts AC to ground on a meter while idling?  Hope this helps, let me know if I can further assist - Cheers!~  Bellarmine
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
    • By mehim
    • By OldATVowner
    • By LMI
