2005 King Quad 700
Took off the front plastic and pressure washed it.  unfortunately while doing this I lost the metal insert of a rubber grommet.  There are 2 rubber grommets with inserts on the front, Left and Right.  The screw that goes through here holds the front cargo rack on.  Any ideas where I can find a replacement?  id take the metal insert or a whole new rubber grommet with insert if I can find it.  Pics are front and back of both grommets, one with the insert, one without the insert.
IMG_1498.thumb.jpg.5045b6954184ea10aef0d3088200817d.jpgIMG_1497.thumb.jpg.8c12b76817ae5a1577dbd4ea03ac25cb.jpgIMG_1496.thumb.jpg.254e4a0b3318e19c593b8b7d53681610.jpgIMG_1494.thumb.jpg.0ae93d74e83bf2a19d4d6e5fafb6ae3f.jpg
A dealer would be one place, but that could be expensive.
I've used Partszilla to find the manufacture part number by looking at their exploded parts diagrams, you'll just have to start picking componets to see if any show the detail your looking for.  Once you find the part number you can then search on other sites (google) to find it cheaper.
Here is a start:
https://www.partzilla.com/catalog/suzuki/atv/2005/kingquad-lt-a700x
Good luck!
    • By tepin
    • By LMI
    • By Johnnynv
      I recently bought a 2006 KFX  700 that had been sitting for 10+ years, started to replace the fuel system and the fuel pump has a connector that does not fit the same as original.  The plug has opposite slot as original.  There are two plugs on fuel pump bracket, some tiny sensor and fuel pump.  The new fuel pump plugs in the same place as tiny sensor, where as the old fuel pump plugged into opposite position.  I took old connector off bad fuel pump and repined it to new one, but now am questioning if this was the right thing to do.  I did pay attention to wire placement but just feel like there should be a direct replacement.  From the pictures on partzilla website, I cannot find a different option.  Has anyone run into this issue?
    • By HoldenBoy
      Hi all,
