I have a 2002 Arctic cat 300 4x4 that died on me.  I was headed out ice fishing and got caught in a snow drift.  I got off and was pushing it while using the throttle, I was making good progress until I heard a "click" then it died.  ATV hasn't made a noise since.  It had fresh oil, new battery, and a fresh rebuild on the carb.  I am hoping someone can help me get it running again or at least give me a starting point.
    • By Elk
      2002 Polaris Magnum 325
    • By tepin
    • By Shorty51
    • By HoldenBoy
      Hi all,
