Looking for private location(s) to ride for my family. Me (Grand dad 65), Son (42) & Grandson (12). All fully experienced and mature. Getting back in the sport after a period of absence from when I had my own farmette (prior to retirement). My location is just Southeast of Reading, PA.
    • By Hank Montgerard
      Is there a 'best in class' tool/app method to map private ATV trails?
      We're lucky to have some space to ride and have created many trails but can't figure out the best/most efficient method to generate a map?
      I've tried GIA GPS for iOS with some success, however the stop/start when trails cross over each other makes it tricky/difficult to get an accurate 'total mileage' vs. duplicate overlap.
    • By NEKExplorer
      I am working on a 2005 Yamaha Bruin 350 4x4. I have all the parts for the oil cooler system rebuild. When I received the vehicle the cooler was not attached so I am not sure which hose was attached to which side of the cooler/radiator. For this reason, I am unsure as to which hose pumps the oil out of the engine block and into the the cooler. Where the hoses atach to the block, the two ports are stacked vertically (upper & lower), but I do not know which hole pumps the oil out and which one receives the cooled oil. I have looked at some service manuals, but they look conflicting to me in that the inflow/outflow points on the cooler diagram page seem to attach opposite of what the diagram on the service manual page showing lubrication points labels the inflow/outflow attachment points on the block. I know the lines in the diagrams are a little hard to follow, but I do beliece I have read the diagram correctly.
      So my question, can someone tell me if they know for sure on this machine which port on the block sends the oil out to the cooler (upper or lower hole) and which one receives the oil back from the cooler?\
      Thanks for your time & any answers
      If you are having an issue where the notification bar stays on saying you have a comment left or message left after you have opened all available, please let us know and we will correct it for you. You can reply to this thread and let us know what's still on.
      Thanks.
