Hi.  I have a 2022 cf moto uforce 1000 xl and I'm looking for switched power by the key in the front for a light bar.  I can't find any power switched on and off by the key.  I've installed my switche or the light bar, but can't turn of the light in the switch.   I thought the winch control up front was switched but it is not.
  • Ajmboy changed the title to 2022 cfmoto uforce 1000 xl switched power location
3 minutes ago, quadmaniac said:
The winch is probably constant on and you would need to just install a new rocker panel switch.
I did install a new rocker switch that has light in it and is constantly on.  I was hoping I could control power to the new rocker switch by the key.  So I can then isolate power when the machine is turned off.  Think I'm just gonna add a rocker switch without a light.
    • By TomJulio
      any ideas how to correct
    • By Adamb2025
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
