Reeds have much the same effect as a cam.. stiff reeds give better low down power, but stifle the revs, and soft reeds work the opposite.
It's all compromise regarding the power.  The thing I'd be looking at is the durability of the reeds..  some break or fall apart easily..
I haven't had much experience but one son loved two strokes for a few years and played around a lot. He eventually decided that steel reeds were better.
    • By noticon75
    • By toe420
    • By Adamb2025
