By Gtc4d
Thanks.
Todd
By jordan_ATV
By TravisCr
By kawasig
By Norseman69
Hi. I just bought an lt230 1993. Ive started buying parts for a full rebuild. But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed. I was wondering if anyone have one and Could measure how far out the pegs are. Like the peg the brake is put on and then peg outside of it. And the one lower down. So i can recreate them.
