1992 Suzuki kingquad 300 with 17000 kms.
New intake boot same old problem. Starts and Idles perfect, wont take any % of throttle. Same tune i had as when it got flooded with water.
All i did since then:
Cleaned the top and bottom of the carb and jets.
Swapped different plastics onto it.
Rebuilt the starter.
Added another ground. (Since removed)
Extended the positive terminal so it can fit without strain.
Added battery.
Swapped carb diaphragm off of another. (No holes)
Did a temporary oil cooler delete.
Flushed and replaced the oil.
Just added a brand new intake boot & gasket....
Had it running perfectly just days ago minutes after i siliconed the intake gasket. It has since melted away from gas i assume. Didn't touch it for 4 days went to go for a ride and bogged and bogged. Replaced the gasket and intake boot to no avail, so i really don't know what's going on now.
The spark plug is dry carbony but it's the same tune as before..
Has good fuel flow in the line, fuel is new.
I was testing spark yesterday and it was bright orange. And it eventually went back to its white, Not blue by any means.
Before i replaced the intake boot it would take tension on the throttle and you would get 2000 rpm max before it bogged..
Since i replaced it, it won't take any at all. Spraying flammable liquids into the carburetor had the same bog result. I tried spraying said flammable liquids around the head boot seal and didn't notice any difference. I didn't try for too long.
boot to head is tightened as much as i could with a screwdriver + less than a quarter turn with a ratchet.
Previous silicone very possibly could have fell into the combustion chamber and did something there??...
No difference with any choke, with or without airbox boot, pressurizing the fuel tank, battery disconnected.. there was a point where i left choke on and had the air filter that came with it on and it flooded the whole airbox with fuel, That was when i was building compression because i lost all of it during the flushing process. (It's back now)
Im lost! This thing was perfect until i got water in the oil and flushed everything and what not. Its only been less than a week since then so theres no chance the fuel went bad.
 Ps the switch is a neutral safety switch bybass. It really hates itself with the switch off. It makes a knocking noise and idles with a surge. Is perfect with a battery connected off and on but without a battery it has to be on..
It acts like the main jet is stopped up, but you cleaned that, so im thinking maybe some of the silicone you say melted may have made its way into the carb, I would check for that if you haven't already done so.
The silicone was at the base of the head. There is no silicone before the carburetor, it does act like the jet it stopped up but i sprayed brake clean right through it and can see light through it clear.
20 minutes ago, spock58 said:
It might be low on compression, have you done a test for that yet?
I have not done a proper test as i don't have the right adapter. The compression is about the same as it was the day water got in it, its enough to just barely hurt your hand upun pulling it over
  • Solution
SOLVED!! there was just a little bit of dirt in the jet on top of the carb where the diaphragm is. Sprayed brake clean through and it popped out if the idle jet screw area. Runs perfect again!
On 5/25/2023 at 12:32 AM, Gwbarm said:
Good you got it fixed sometimes little things will drive you nuts, you did a lot of work , thats a good thing now you know its all nice and clean.
About that. It wasn't the problem. It was a tube i put over the vents to prevent dirt from getting in. I tore a quad apart because of a 2 inch peice of rubber haha
    • By Atomusthenes
    • By RadRob
    • By Memphis
      Regards
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
