I just bought a 2022 Sector 550, it has 22 miles on it.  Driving down a flat gravel road for 2 miles, and it starts blubbering and missing.  Then it catches and runs fine for a bit, then starts blubbering again.  Then I went up the neighbors steep driveway and it blubbered and then ran Ok, then blubbered again, then ran ok, then blubbered again, I wasn't sure I'd make it.
Got home, let it cool down and then recreated the trip.  Two miles of level gravel road, then it started blubbering again.  Didn't try the neighbors driveway.  Didn't want to have to walk home.
It seems as if when it reaches a certain temp it starts acting up.  It isn't getting hot, gauge reads good.
Any ideas?  Years ago a Polaris snowmobile was acting up like this and the temperature sensor wire was loose.  That is not the case here.
It seems like an "Ignition Interuptis" scenario, but not sure where to look.
Fuel?  New machine with new gas?  That shouldn't be it.
Probably going to take it back to the dealer tomorrow, but am hoping to get any ideas from you Hisun guys.
Any ideas???
Thanks for the help.
Clydaho
Water in the fuel.
I refilled the tank with fresh gas, added Sta-bil and heet.  Ran it up and down the road and cleared it up.
I think it was sitting at the dealer for a year, hence the moisture in the gas.
Running like it's supposed to.
I guess that would do it, I just assumed the dealer would have put fresh fuel in it before they sold it. Great you got that figured out, beats hauling it back to the dealer.
Just bought an Axis 500 from Lowe’s. Same exact scenario. Filled up with new gas, all is good.  My guess is they put some gas in at Texas assembly and a year later by the time they finally sell, that gallon of gas has moisture in it.
Another possible scenario that some Hisun Sector owners will run into is the seat belt governor. If seat belts are not fastened, the vehicle will not go over a few miles an hour and it will buck and hesitate like there is fuel starvation or an ignition issue. It took me a long time to find any documentation on this. However, I did find a sticker on the left side roll cage that provides a warning.
Yes, I experienced this seat belt nanny first hand. Found a mention of it in a note buried in the manual, then found the warning label after that. Hooked up seat belts (like we're supposed to) and problem solved.
k-bo
    • By BillR94
      Thank you for your time
      Bill
    • By shorty
      First ATV but owned 2 wheel versions all my (long) life. 1990 KLF300C for $500.. doesn't run yet but I'm an old automotive mechanic so not worried. Only a little concerned about the price of parts, certain this antique will need many
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
