The Kawasaki is a 1989 Bayou 220. Neutral has been found, by pulling the recoil starter, engine turned over the wheels did not turn, so my next step is to put a battery in and see what happens. Oil is half way up the sight glass. The concern I have is the throttle lever is not moving. Suggestions please?????
What Gw says..
Try pulling on the throttle cable where it goes into the carb at the side..  It should pull out about twenty mills if the butterfly is free, if it's seized then it won't move more than about two mills. If the butterfly is free, then it's the cable or in the hand-piece. Try pulling the cable out at the hand piece, if it pulls out about twenty mills then it's the hand piece seized. if it doesn't pull out there its a seized cable.
    • By logray
      Hi all,
    • By OldATVowner
    • By LMI
    • By HoldenBoy
      Hi all,
