The readout screen on my 2006 Suzuki king quad 700 is fading out to the point where it is getting hard to see, especially on a sunny day. All the readouts are still there & working just hard to see like a dimmer switch is turned down low. Any ideas on what is causing this issue???🤔
  • Ajmboy changed the title to 2006 Suzuki king quad 700 Readout screen fading
  • Solution
The lights are led, and the rest of the display is LCD.. Are the lights dim as well, or just the gauges etc ? Lcd needs a good power supply.. You could check the power supply and earths.
It's also possible the dash is meant to dim if the lights are on..  I'm not sure about that, but it's a possibility. The owners manual might mention it. The service manual I looked in didn't mention it. You might try turning the lights on to see if it makes a difference.. It shouldn't, because they are already dim.. haha.. but we never know what might reveal itself. Turning the lights on will turn on the dash lighting and put more load on the earth and/or earth.. I think..
The whole display is dim. I can barely read the fuel gauge. I usually always have a fully charged battery in it. Maybe the display is just going bad, 🤔
It could be..  Could you try putting it on a buddy's bike to see if it looks the same, or borrow one for a few minutes.. They only need to be plugged in to try. If you walk into a bike shop they might test it on something in the workshop if you bribe them.
Thanks Mech, I don't know anyone else that has a king quad, but I'll keep digging. I hear that they are kind of expensive to replace. Maybe I will figure it out.🤔
I'd check that it was getting full voltage at the power pins, with the gauge connected so there was the usual working load on the connection. If you just check the voltage with the plug disconnected, and there is a bad connection, it can show 12v, but then drop right down(or a little down), as soon as the load comes on. There are probably two power supplies to that gauge, and perhaps more than one earth. I'd check them all..
  • Thanks 1
Yeah I've seen lcd displays get faded..I think the only test for it will be to ensure it's getting full power and earth, because they are quite current dependent, and as long as it's getting power to the gauge then the conclusion is that the display is dying..
15 hours ago, Gwbarm said:
I have seen those LCD gauges get weak and fade over time, but would check voltage as Mech suggested, and also ground could be weak.
Yeah, I think the display is just dying. Will keep my eyes open for a good used one.
    • By docdoug72
    • By Thekevinjb
      thanks
    • By RadRob
