Hey y’all, so I have this 02 Honda foreman rubicon 500fa that I just got running after who knows how long. But a couple issue came with the start up and I need some help.
1.  While idling and full throttle it’s smoking pretty bad. I think it’s the jug and/or piston rings.  Could someone tell me if I’m on the right path.
2.   When I put it into drive, the hondamatic has a high pitch squealing and it barely moves. I put it in reverse and doesn’t move at all.
Any ideas or possibilities I can look into?
How does the spark plug look shiny black or matt black, what color is the smoke, does it ever let up or smoking continuously.  Trans coulld possibly be a bad bearing does it have plenty of fluid in it.
There was a fellah in here a while back had the same symptoms, the squeal, stripped it right down and found nothing, put it back together and it seemed to be right.. Do a search for hondamatic and you mioht find it.. I think it was in this site.. If not it was over the way and I'll have a look tomorrow.
I'm pretty sure he found nothing..  Might have just needed an oil change.. haha
  • Admin changed the title to 2002 Honda Rubicon 500FA Issues
    • By Atomusthenes
    • By Trent Finnessey
    • By Tinkeringreg
    • By Dumass
