oil cooling fan and temperature light
is there any way to test these? i know the fan works if i jump it, and i believe i heard it turn on once when driving, but the light has never come on. the bulb is good ( i checked it on the bench)
is there a way to test the sending unit for the oil temp?
You really need to get the manual and follow it's diagnosis process.
There is a temp sensor, a temp control unit, and a relay and circuit breaker for the fan. If neither the fan nor the light come on it could be the unit or the sensor, but the light is meant to come on when you use the electric start as a check, so follow the diagnosis process to make sure you find the problem
i tried looking at many manuals for this issue, they all seem different. But, i saw on a diagram when i followed the wires supposedly for my year and make, there is something called a "oil temperature indicator light checker" near or in the main switch on the handle bar.
I jumped the oil temp switch earlier and the fans turned on, but the light never did. supposedly it's supposed to light up when the fan goes on.
Is that oil temperature light checker a real thing? i can't seem to find any info on that
If this is the 2000 BB400 then this is what you need I think.. As always, if the wire colours don't seem right let us know.. Yamaha love to change their wiring.
One thing to note is that the wire going to the temp light changes from R/w to Br at a splice in the main power wire from the fuses. Those splices(shown as dots on the wires) are sometimes just crimped joins and can get dirty when they are old.
output.pdf
fixed! a couple of bad connections i found following your diagrams.  light works now
thanks a million!!!!
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By Vlaco
      I want to replace the factory headlights with LED bulbs. Any idea a good one to get?
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By motox88
