Polaris solid axle locknut tool?
Go to solution Solved by Mech,
Thanks Mech, I found some things called torque wrench adapters but can't find them big enough. I see the crowfoot and flare nut adapters. Not sure if the flare nut type would handle the torque or not...
  • Solution
I doubt the flare nut type would be made for that torque..
To tell the truth though, I doubt it needs to be torqued precisely. If you have a torque wrench that goes to 150, or close to it, put it's drive in the vice and get a feel for what various torques feel like, like start at eighty and then try one-hundred then one-twenty or whatever your wrench will go to, then just make an estimate and do the inner nut up reasonably tight and then crank the outer/lock nut up to as close as you can calculate it should be with a plumbers wrench/pipe wrench or big crescent.
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
