By mga
So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
By Doublewidekings
I am looking for what you would consider the best ATV winch for under $125. Thanks in advance.
By Cobra_kai83
The gas in the tank was bad so I drained it and put new fuel in. It still wouldn't run so I took the carb out and cleaned it. Re-installed the carb and now it will only start and run under full throttle. It also runs rough like this. The engine stops running once I back out to 1/4 throttle. What the heck is going on?
By Buell
Hey guys, figure you guys would have some helpful direction or answers.
So, 05 Sportsman 700 carb, new carb, fuel pump, new plugs, new air filter, new everything I can think of that is usually the running issues. Starts up fine, seems to run fine, but if under load, two people, or even one person, up a hill, or pulling a drag chain for the driveway, it starts to cut out and sputters and loses all power, until I back off on the throttle and just barely try to let itself catch itself and then I can take off again.
I am going crazy trying to figure this thing out. Other than that, the quad runs great. Parents bought bran new, just used around the property, 5000 miles on it. Any ideas???
