By logray
Hi all,
By HHurks
Thank you!
By rjsummer
I have a 2015 Outlander L 500 max.
any way to change the start up message in the cluster WITHOUT taking it to the dealer and paying $100???
By quadnut20
Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
By sunn
Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted. The atv started, but then died a couple times after repeated attempts. But when run awhile everything was ok. Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
Is this typical of a failing fuel pump?
I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM. Just had all covers off so looks really easy to replace.
Any ideas?
