Looks nicely made.
I just use a hammer to knock the pins out of master links and a pair of channel-lock pliers to put them together. If you position the link on the back sprocket the pins can be tapped out easily.
Yeah I mounted it on the back sprocket. I think the open end of the clip is all the way on. I'm going to replace the chain and sprockets soon so I may get that press so I I'll have it for that job. Thanks! 👍
I think I'll get on for when I change sprockets and chain. I ordered snap ring pliers for the snap ring on the front sprocket. The ones I ordered have .470" pins I hope. I hope the pins will fit the holes and not be too big or too small. 🙂
Oh yeah. I've got a set of those. I think you'll find they are fairly small tips, good for piston circlips and brake cylinders, circlips about fifteen mill diameter. They'll do a sprocket circlip though.
They'll be 0.047" which is close as to 1mm.
Edited by Mech
I was trying to decide between the .070 or the .047 I finally went with the .047 As long as they will work and not brake I'll be satisfied. 👍 Also had .090
Edited by p5200
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Dutchaaron
    • By captnunu
    • By toe420
      New member from BC. Anyone else from western canada?
    • By NickPence
      Just wanted to drop a post to say hello. My name is Nick. I am from the Shenandoah Valley. Rockingham Va to be more specific. I am constantly working on junk or items i pick up from auction, mostly atvs but really about everything. My ATV knowledge is vast but find myself needing assistance regularly.
