Check the bendix to make sure it is working properly, you might pull the starter out and check it out to make sure all the parts are in place and and no slop in the engaging gear.
Thanks everyone i just have one more problem. The speedo is blank so i don't know mileage or the hours. If i replace the speedo with a second hand one will it read the mileage of my bike or of the previous bike?
Have you tried putting voltage directly to speedo to see if it will come on, if so then you know it works and you can start tracing wires to see where the fault is, if not it just might be an internally shorted speedo. You could try taking it apart and see if the circuits are coroded and clean them up and see if it helps. Just some thoughts..
Thats not all bad at least some activity out of it, it sounds to me like the sensor that send the speedo information is shorted out. You might locate that and make sure it has a good ground.
  • 2 years later...
For what it’s worth, I have an 05 Outlander 400 with the exact problem, bendix not staying engaged more that a second or 2 when starting. I order a new one and replaced it.
Same symptoms.
Turns out my battery was on it’s last legs. It cranked, but not hard enough I guess. Put a new battery in, bendix never disengages now. Oh, and I now have a spare bendix…
Edited by rjsummer
Missed a word.
    • By Joeguy
    • By canamKID
      20260711_150338.mp4
    • By realpilot
    • By mehim
    • By logray
