Oil change diffrentials/gearbox Outlander 570 2021
I'd generally only change oil if it had got enough moisture or water in to cloud the oil, or(and this never seems to happen) the oil looked really thick and black. Mostly an oil seal goes before the oil looks bad and the oil gets changed then.
    • By Werewolf
    • By JohnnyB
      Greetings,
    • By Mhatayas
    • By mga
    • By jatho
