Hey,
I have had this quad since new. The oil change is a pain in as* cause I have to remove the plastics, foot well, etc to be able to get to the drain plug. Any one have an easier way?
Cash
  • Ajmboy changed the title to 2008 polaris sportsman 500 X2 Oil Change
It is kind of a pain, but I have never removed anything, on the left side at the Botton of a plastic cover, through the wheel well is the first drain plug remove it, drain the oil, also on the left side is the oil stick and screw on filter which I like very much, get to it fine with a ratchet and filter wrench, the other drain is at the bottom , had to lay under it, never removed anything, there is an opening ,you will see 3 bolts take out the one in the center, need a long handle ratchet, let it drain and replace the plug, you are done.
      I have a 2015 Outlander L 500 max.
      any way to change the start up message in the cluster WITHOUT taking it to the dealer and paying $100???
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By middlebrookgt
    • By C2INS
      Does anyone know if they're interchangeable?  I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
