Yamaha blaster
can you get klotz at like autozone? and is there any perticular type i should look for?
Any 2 cycle oil will work. Get yourself a measuring devise. And the Razr2 are designed for GNCC. They will work just fine on MX track. Maxxis also makes track version of the tires as well. The Razr is for track. ITP has the same thing. They have Holeshots for GNCC and Holeshots for the track. The difference is the weight and the ply. The tread pattern may be a little different but for the most part it's the same. If you buy the tires for MX, they are lighter than the GNCC tire but it's only a 2 ply tire.(2 layers) The GNCC tire is gonna be better for trails and stuff. They are 6 ply. Takes alot more to pop them.
These are the ITP
Itp Holeshot Xcr Rear Tire 20-11-9 - Tires Online at MotoSport
These are the Maxxis
Maxxis Razr Ii Rear Tire 20-11-9 - Tires Online at MotoSport
Let me know what size rims you have now.
Hey SunL. I have a pair of red and black Acribis Hand guards with all the hardware. Have never been mounted. You want them? I will throw them in the box with the manual. I bought them and didn't like how they attach. You're more than welcome to them.
This is what they are.
Acerbis Vented Flag Hand Guards: Onoffroad-ON OffRoad
will they fit the blaster?:confused:
I hope you can use them. I won't be hurt if you don't like them. I'm the kind of person who doesn't like change a whole lot. In order for them to work I would have to reposition my front brake lever and the clutch. Not a big deal to the average person, but I'm weird.
i have the same problem, i hate to change things
    • By Need-help-with-quads
      Can anyone help me?
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
    • By newguy024
