I've got the stock wheels and tires off my 2008 Arctic Cat 400 4x4 for sale.
I bought it in June, and they have around 15 miles on them.
The wheels are the gray finish - 12x7 front, 12x8 rear.
The tires are Goodyear Rawhide RS - 25x8-12 front, 25x10-12 rear.
I'm asking $250 for the set.
    • By jay41198
    • By tepin
    • By Shorty51
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
