Very nice ride! The only 2 factory flaw problems i have heard of are dropped valves, but that would happen at very low hrs,  and defective air intake clamp.
But here is a list of riders complaints.
Here are the 15 most common Yamaha Wolverine problems:
  1. Hesitation when accelerating
  2. Issues with EPS
  3. Glowing exhaust
  4. Header pipe cracking issues
  5. Stuck parking brake
  6. Flooded fuel tank
  7. Oil consumption problems
  8. Excessive cab heat
  9. Clutch slippage
  10. Clunking noise
  11. Heater problems
  12. Cramped seating position
  13. Underpowered engine
  14. Displaced foot brake
  15. Riding comfort
What kind of problems are you having.
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By mikeexplorer
